r6 shock
ant75
- Bike owned: yamaha r1 5vy,vfr400 nc30 91
r6 shock
hi all, ive just bought a yamaha r6 07model shock brand new and very cheap,was wondering has any1 fitted 1 to an nc30? i know their shorter is their any mods on jacking the back end up?
Tombola
Re: r6 shock
jacking the back end up does make a bike handle better apparently,i tried putting a cbr600rr shock into my nc24 and i couldnt make it fit, even with a fair bit of grinding!
renewing the oil in your old one would be a safe bet and getting a stiffer spring from demon tweeks
ant75
Re: r6 shock
ah thanks but i know this shock wil fit,just wonderd if anybody had any ides how to jack the back end up.
- bikemonkey
Re: r6 shock
Shorten the dog bone link, just check everything clears, that hole in the swingarm isn't huge.
Re: r6 shock
You could try one of these http://www.projection-components.co.uk/ ... s-17-p.asp
There made to fit a FZR but kayla will probably modify it to fit the NC for you. What length is the R6 shock?
ant75
Re: r6 shock
the r6 shock is 291 and the nc30 is 305,wil shortening the dog bones work?
Re: r6 shock
Dont know, i think you'd run into clearence problems shortening the dog bone link enough to get the right height. You could get a spare one and experiment but doesnt changing the length of the link effect the spring rate etc?
ant75
Re: r6 shock
i think your rite,getting that adaptor is better but a little pricey tho.thanks for the help
Re: r6 shock
Thinking about what i just said and it doesnt really matter about the spring rate etc cos the R6 spring is going to be way too soft anyway.
scooble
Re: r6 shock
I put an R6 shock on my KR1 and it was too soft - so I got it shortened, re-valved and re-sprung
