NC30 forks adjusters
tonfanau
- Bike owned: suzuki 884 bandit, NC30 Z750
Hi, my NC30 fork adjusters need replacing as one of seized and even with alot of lube and heat it still didn"t move, now the top brass screw has snapped and buggered the whole adjuster up, so my question is where can i get one from, anyone got on here or any other help would be great, thanks Alister
Re: NC30 forks adjusters
Rick Oliver sells aftermarket replacements, so do Tyga.
Or you could try your luck for a used one on the classifieds.
Good luck with that. The first point would be to post an add in the wanted section.tonfanau wrote:Hi, my NC30 fork adjusters need replacing as one of seized and even with alot of lube and heat it still didn"t move, now the top brass screw has snapped and buggered the whole adjuster up, so my question is where can i get one from, anyone got on here or any other help would be great, thanks Alister
I gave up.
You can get aftermarket ones from Rick O for around 80 quid.
The fork top is only avaiable as part of the dampening rod so very expensive.
I eventually brought a secondhand fork, and the fork adjuster was siezed to shit. After having much expereicne by now pissing about with them it is a ball ache but they can be unfreed.
Too late if youve snapped the brass adjuster.
Cheapest option is to look for forks that are for spares, i.e crash damaged bent ones that can be had cheap, often they even fetch good money as the lower legs fit the CBR400s to give good brakes and the fork tops are wanted by nc30 owners with knackered parts.
- RickOliver
Hi, Alister -
Pics of my replacement fork tops here -
viewtopic.php?f=64&t=17868
In stock, and in Norfolk...
Rick
01603 720387
Rick
01603 720387
tonfanau
Hi Rick
Thankyou for your info, i will ring you very soon,
And thanks to everyone elses comments i appeciate it
Alister
Alister
