Re: NC21 odd sound diagnosis help
Posted: Fri Nov 16, 2012 10:51 pm
by thunderace
Warped disc or wheel bearing/headstock bearing.
Posted: Sat Nov 17, 2012 12:09 am
by RICKNC31
Sometimes you can get a ticking sound from just a dry speedo cable so worth a check just in case hope this helps rick
Posted: Sat Nov 17, 2012 12:42 am
by Cammo
Stiff link/s in the chain?
Posted: Sat Nov 17, 2012 4:06 pm
coreygun wrote:Ive been looking around the rear hub area, and I know the calipers are rubber mounted, and so have a little play, but the plate which comes from the swingarm, which the caliper is mounted to also has a bit of play. Is this normal on an NC24?
The NC24 has a single sided swining arm and a different caliper.
