NC21 odd sound diagnosis help
thunderace
Bike owned: R6, YZF600R
Re: NC21 odd sound diagnosis help
Post by thunderace »
Warped disc or wheel bearing/headstock bearing.
RICKNC31
Post by RICKNC31 »
Sometimes you can get a ticking sound from just a dry speedo cable so worth a check just in case hope this helps rick
Cammo
Post by Cammo »
Stiff link/s in the chain?
coreygun wrote:Ive been looking around the rear hub area, and I know the calipers are rubber mounted, and so have a little play, but the plate which comes from the swingarm, which the caliper is mounted to also has a bit of play. Is this normal on an NC24?
The NC24 has a single sided swining arm and a different caliper.
