Starting problems NC30
mikey65
- Bike owned: 2012 Fireblade HRC NC30 K 1989
I have not started the bike for about 6 months have charged the battery but the engine will not turn over at all. The bike is on 2 stands as I am in the process of rebuilding. I wanted to give it a service so need to start and run the engine before I change the oil. I have changed the air filter the bike has started and run well before do you think I shoukld try carb cleaner and if so do I remove the tank and airfilter and spray into the intakes never done this before after any advice.
- bikemonkey
Re: Starting problems NC30
It won't turn over at all?
Let's start easy
Kill switch on RUN?
Main fuse intact?
Starter solenoid working?
Bike in neutral with clutch out when trying to start?
Clutch switch intact?
And whats the battery voltage? < could be a fuckered battery even if you have charged it.
Let's start easy
Kill switch on RUN?
Main fuse intact?
- speedy231278
mikey65
I am getting about 12.7 volts from Battery. I have not got a fuel tank breather at the moment the cap was broken will that make a difference.
mikey65
neutral switch is working. main fuse is ok to.
mikey65
mikey65
Kill switch is in run position
- speedy231278
When you say won't turn over, do you mean the starter won't turn the engine, or the engine refuses to turn over under it's own power? If it's the latter, maybe your breather issue is preventing the tank from breathing correctly, and the fuel is being held in the tank? If so, what happens if you open the filler cap and then try to start it?
mikey65
not thought of that i will try it.
mikey65
still the same eer eer eer eer the sound but will not fire.
