Carbon fiber parts
- xivlia
- Bike owned: Ducati 749 D
Carbon fiber parts
Hello, yet again im coming out with one of my "want to do's" but this time i really am planning on doing this.... own carbon fiber parts.  here is the stages...
1. Make a mold of the part that i want to make
2. use the mold and apply real carbon fiber weaves and resin.
3. use the part.
there is mold making kits and carbon fiber laminating kits available. i am thinking of starting by making small things. like airbox and fender. I know you can already buy them, but id like to make and sell them for cheaper than they are going.... 40 quid for a laminating kit, and i could sell them for 60 quid. and keep 20 for my self.
once i get the hang of it. maybe even try the fuel tank. ive already got a way of making the fuel tank in my mind, the question is, will it work :D
thanks!!
3. use the part.
thanks!!
- VFRkieran
Re: Carbon fiber parts
Fair one for wanting to give it a go, but i cant help thinking theres something else your money would be better spent on...
						- xivlia
true, true hehe. of course i will first buy all the the things i need for this bike before i work on cosmetics, i am not making the same mistake as i did before.... buying bodykits and stuff before the bike even worked properly.
here is what i am wanting to do over the winter before i do any carbon fiber or any cosmetic stuff..
bmw s1000rr shock upgrade
check valve clearances
fix the carb number 1. float leak (buying new float, seat, needle from Rhory)
K&N filter (buying one from a member here)
oil and oil filter change.
after all that. THEN its time for cosmetics, assuming the bike will be working properly. its running now and i am using it, but i want it to run better. and after i do all of those i think itl be safe to say the bike is fully working.
Cool, i'll have a NC30 fuel tank skin when you've done it.
Where are you planning on doing this though? from what i gather you dont even have a garage to keep the bike in.
				vic-vtrvfr
I work in the aerospace industry & gotta warn you - be careful.
Carbon fibre & fox piss really dont mix well......
Just joking, good luck with it. Make sure theres plenty of pics.
- thunderace
- Bike owned: R6, YZF600R
In the correct order for youxivlia wrote: fix the carb number 1. float leak (buying new float, seat, needle from Rhory)
						- xivlia
i do have a small aluminum shed that i can use to keep the parts. :) i will take plenty of pics, and thunderace, that is the order i was going to use
- speedy231278
				The Novice
That made me laugh.vic-vtrvfr wrote:I work in the aerospace industry & gotta warn you - be careful.
Seriously though, fair play, Have a word with Ricki - Porndoguk - i am sure he made a rear seat cowl from carbon fibre and recall that turned out well.
Ideally an Autoclave as you can heat with atmospheric presure,speedy231278 wrote:Doesn't carbon need baking to cure it?
Ersan You'll also need vacuum bags, and source of creating the vacuum,
lots of bits needed to set it up professionally that a DIY kit does not offer its just that DIY
Yes I made a carbon seat cowl its far from perfect, it was made on a drape over basis, no autoclaves or vac bags, just a heat matt over night in a warm kitchen.The Novice wrote:That made me laugh.vic-vtrvfr wrote:I work in the aerospace industry & gotta warn you - be careful.
your not the first person on here or someone I know that thinks its posible to create professional products with minimal cost it is not posible.
Give the idea up
Fail to plan, plan to fail
Rick
