Is my battery knackered?
Posted: Sat Nov 03, 2012 3:44 pm
I'm still losing volts from my battery (they don't seem to be hiding in the battery box
), so I'm pretty sure the only thing left to blame is the battery itself. However, just to make sure it's not something else and I'm not going to knacker a new one, here's the story so far:
Ages ago I discovered by accident (I broke one) that the alternator wires were very unhappy, and replaced the the female spade connectors with new ones. I don't think this really has a bearing on what's going on but bear with me...
Some time later, at least a couple of months and many hundreds of miles, I came back home for the weekend to find that the battery was flat to the point it wouldn't throw the solenoid. Recharged it, checked the repaired crimps, all were fine and everything went OK.
Next time I came back, everything seemed OK.
The following occasion, I decided to measure the battery out of curiosity. 12.25V! Bike started, charging figures were not great but within spec. Re-crimped previous repair and soldered for good measure. Test ride charged battery a few tenths higher. Next day arrived at destination convinced something was amiss. Charging system appeared not to be working (lights not glowing when engine revved, no slight flicker when shutting throttle). Test rode twice during the day seemingly without issues, but both times charging seemed to work when setting out, but not working within a few miles. Leaving the bike for a little while and then running again seemed to bring it back to life. Rode home (25 miles), arrived with bike running on 9.5V at idle. Climbed to about 11.2 on turning off ignition.
Today, I have cut back, crimped and soldered new spades on the alternator connection by the right fairing bracket, and fitted a new connector. I have also put a new connector on the reg/rec, replaced the previous crimped repair on all the pins (this was done about 5 years ago or more) with soldered spade connectors, and the output is now direct to the battery via heavy multicore and a fuse on the positive, using proper battery connectors. Freshly charged batter applied, and the results were very good. System produced 14.5V at 2K never mind 5, with a few tenths less at idle. Haven't managed more than high 13s before, so I was really happy.
I went out intending to put similar miles on as the last journey, however after I stopped to get petrol, I noticed that the headlights appeared to be dimming in time with the indicators, which is usually a bad sign, so despite having a few tools with me and a meter, I headed straight back home. 11.99V after less than 10 miles and one re-start of the engine.
Nothing happened if I gave it a few revs, not even a tenth of a volt more. After switching off, it raised back to about 12.4V, and the bike would start if I tried.
I checked all the wiring again and everything was sound. I put it all back together, and once again it did the trick of suddenly working again, however I was not happy. Elsewhere, someone suggested that if a battery can't manage half an hour with full beam on with the engine stopped then it's junk. So I decided to put the meter across it and see what happened. It managed about 10 mins before there wasn't enough oomph to turn the starter (the solenoid still threw).
I'm fairly happy to say the battery is crap, or would be if it was a few years older! However, I'm a bit confused about it not charging, then charging, then not. If it charges from a charger, why not from the charging circuit, and also, if the charging circuit is working, why do I get such a low voltage when the battery is sulking? Does it somehow cause the difference between what should be about 14.5V output and what you actually read to become 'lost'?
