making an underseat tank....
Posted: Sun Sep 28, 2008 11:41 pm
I finally got round to attempting an underseat fuel tank for my NC30 project. With a rough idea of what I want to achieve I start by making a big block of foam from which to carve out the shape of the tank.
(You get some really cool shapes formed if you put too much expanding foam in the box!)
With the foam then roughly the right shape (and fitting into the space I have available) I apply double-sided sticky tape all over to hold a layer of release film. This will mean that I should be able to easily remove the foam when digging it out. With everything wrapped up it is off to be dressed in carbon...
The tank is made in two parts which will be joined together.
The foam is carved out, and then the tape/film just pulls right out, nice and easy with nothing left sticking to the inside.
The two parts allow me to work on the inside of the tank and prepare all the fittings.
I include a cap from an old oil bottle, an MX style breather and fuel in/outlets. Due to the complex shape I also figure that I need a number of extra pipes to stop the air getting trapped.
With everything joined together and sealed up all that remains is to secure to the bike. At this point in time the exact fixings are undetermined but I have a few ideas.
The tank will hold 6 litres in total, which should be enough for one race session. This will be coupled to another tank in the normal place, which will allow the use of the normal filler cap and more storage if needed for longer 'trips'.
To Do:
Basically finish the tail section, this includes making the rear fairing from carbon, then putting together something to fill the gap around the tank and fairing.
So, why do this?
Well, the fuel in a bike weighs quite a lot, and normally it is high up over the engine. In theory, mass centralisation is a good idea so lowering the height of the bulk of the fuel should lead to better handling.
With the original fuel tank gone and replaced by a carbon shell, this allows for modifications to the airbox and space for electrics, whilst still leaving some space for a small fuel cell.
Chris
To Do:
So, why do this?
Chris
