front lights not working right
Posted: Sat Oct 06, 2012 12:50 am
by badgerskunky
hi guys took my nc30 for its mot today and it failed on the headlights.
it said on fail sheet that o/s head light was not bright enough on dipped beam and dose not light up at all on full beam?
i have replaced the bulb with no luck, what could it be?
any ideas?
thanks kev
Re: front lights not working right
Posted: Sat Oct 06, 2012 10:05 am
by bikemonkey
Have you checked the wiring is all intact?
Probably a good idea to get your switchgear apart too, can get mucky.
Posted: Sat Oct 06, 2012 11:01 am
by lizard821000
appoligize for hi-jack
but on the note of lighting, i noticed other day on the nc that both lights work together at all times, so low is both and high is both, on most other bikes with 2 head lights its normally 1 for 1 and the other for full beam etc..... is this right on the nc?
Posted: Sat Oct 06, 2012 11:16 am
by bikemonkey
Both lights should work whether your using side light, dipped beam or high beam
Posted: Sat Oct 06, 2012 11:25 am
by speedy231278
Seems a bit odd it should fail on one of the lights not working. People out there have single headlight conversions and they don't fail! I guess it's the old adage of if it's fitted, it must work right. Having said that, I have had a few MOTs where the headlight aim was a fail, and they only adjusted a single headlight, saying that was good enough....
Posted: Sat Oct 06, 2012 3:15 pm
by lizard821000
bikemonkey wrote:Both lights should work whether your using side light, dipped beam or high beam
cherrs mate
