NC30 and Other NC swing arm
RandomDan
Post by RandomDan »
What are the differences between the VFR and RVF swing arms? I know the RVF wont fit now!
Is there any difference between any VFR swing arm?
I have an NC30 so would an NC24 arm fit? (hypothetically)
force-v4
Bike owned: Far too many now!
Re: VFR and RVF swing arm
Post by force-v4 »
As far as I know they're all different.
I know the nc30 swing arm is wider than the nc35 swing arm & there are also differences in the rear caliper mounting support arm.
There is also a difference in off-set between the nc24 & nc30 swing arms, as far as I'm aware.
RandomDan
Post by RandomDan »
Dont suppose you have any pictures for side by side comparison?
Just had a look and the RVF has a smaller stem bolt so wont fit!
What about NC24 though?
speedy231278
Re: NC30 and Other NC swing arm
Post by speedy231278 »
http://400greybike.com/forum/viewtopic. ... e870e911d8
Second post shows the difference between RVF and VFR NC30 mounts.
RandomDan
Post by RandomDan »
speedy231278 wrote:http://400greybike.com/forum/viewtopic. ... e870e911d8
Cheers but
'You do not have the required permissions to view the files attached to this post.'
but if its the picture im thinking i saw it on another post im just trying to find out now if other model vfr 400s will fit.
Why?
speedy231278
Cheers but
You're not logged in to the board.... Works for me, I logged out, and it says the same as you posted above. Logged back in, it appears fine....
RandomDan
Post by RandomDan »
CMSMJ1 wrote:Why?
There is a scrape out of mine where the left footrest was bent back into it :(
RandomDan
Post by RandomDan »
Cheers but
Every time i click on the link it logs me out O_o
speedy231278
RandomDan wrote:
CMSMJ1 wrote:Why?
Mine's got one of those too. In this case, it seems to be where someone fitted an aftermarket rearset and didn't realise the thing was too close. If you want another NC30 swinger, look on eBay, there's usually several up for grabs. I spotted a cheap one for my 35 yesterday, but some muppet has powdercoated it - over the surfaces the rear hub pinches on!!!
