carb removal help please!!
Baz
- Bike owned: VFR NC30 (91)
Hi guys, I need to get my carbs off but have hit a problem from the start!!
The bolts holding the carb rubbers tight are all worn and I can only undo 1 of them.
somebody has had a go at them before and made a mess of the bolt heads! I have tried WD40 but they aint budgin'
Any wonderful special secret way of removing them? I won't tell, I promise!
I have new bolts to replace them with so it doesn't matter if I f*ck em right up as long as they come off!
's please.
(It's an NC30 by the way)
- jetblack
- Bike owned: '89 NC30 SEED
Re: carb removal help please!!
do you mean the screws on the jubile type clips?
Baz
Yep but i've done it!
managed to get 3 loose (1 top and 2 bottom ones) and then just pulled and wiggled till the carbs popped off!
I have had to hacksaw through the bolts to get em off but like I said I have already bought new ones.
Its gettin dark now and I dont have lights in my garage so I will continue tomorrow.
Thanks.
Thanks.
The Novice
give it a hoover and clean before you carry on. Sounds saft but you dont want little metal filings finding their way through the engine.
- jetblack
And once the carbs are off, stuff the inlet holes with some rags to stop anythng else dropping in there!
