Float height adjustment
				Mang
- Bike owned: FZR 400 RR SP
Can any one point me inthe right direct as to how to do this. I am sure I am not the first person to ask so wondered if it was already on here
				The Novice
Re: Float height adjustment
viewtopic.php?f=10&t=38305&p=276611#p276611
see this - i have just done mine, you just bend the tab on the float to get the correct height.
I was neew to it and it was confusing me but i have just done it, and the bike seems a lot better at tickover now. (I did balance my carbs aswell though)
Hope it helps you.
Hope it helps you.
The manual will give you a fuel height, you attach a clear tube to the float bowl drain and measure it against the carb body. The tube is a Yamaha part.
