Front wheel fitting problem please help!!!
r_bridges24
Post by r_bridges24 »
Hi I took my wheels off to get new tyres fitted, I kept the spacers in the correct order but then dropped them and now I'm not sure what order they go back in, I consulted the haynes manual and it says the big spacer goees on the rhs hower is thi s as you look at the bike or sittibg on the bike?
I put them in and the disc seems to run very close to the fork.
Thanks rory
amorti
Regular Member
Bike owned: CB-1, MSX125
Re: Front wheel fitting problem please help!!!
Post by amorti »
Welcome
there's only two possibilities, assuming you get the wheel the right way round, it has an arrow to help. If it looks wrong it is wrong, try again.
r_bridges24
its the wheel I have a problem with I can see the arrows its which way around the spacers go as one is wider than the other
thanks
r_bridges24
not the wheel sorry
Hadies
Post by Hadies »
It should only go in properly one way mate. Try one way and if it doesn't line up properly, try it the other way.
Adrian89
Bike owned: NC23 and '05 Blade
Post by Adrian89 »
The right of the bike normally refers to as you are sitting on the bike.
You wouldn't say the right of the car and mean when you are standing in front of it looking back towards it...
