Which is the input trigger wire?
Baz
- Bike owned: VFR NC30 (91)
Hi, I am trying ti fit an alarm (Cyclone V2) to my NC30 and am stuck on the final connection.
the instruction says:
"Connect the blue wire to the input trigger wire at the start relay."
It also says it should be a small red wire.
I have found the start relay and exposed the wires but the only red wire is fairly thick. There is also a red/white, red/yellow & red/green.
The red/white is also thick and the red/yellow & red/green are both thin.
Anybody any ideas?
I think it will be the thicker red wire but not 100%
Anybody any ideas?
- thunderace
- Bike owned: R6, YZF600R
Re: Which is the input trigger wire?
It's the same as the Hornet so it's the red/yellow wire. That's the one from the starter switch (the trigger)
Baz
Cheers mate!
glad I checked cos I would have cut the other one!
Baz
Alarm all finished now. (thanks Thunderace).
Hopefully it will now be safer and deter the thieving b*sta$ds who nicked my KTM!
- vfrman
- Bike owned: NC30, 1098s
I find a shotgun deters them better than any alarm...
