bike stalling/jumping at low revs (3-6000rpm)
hi all,
i recently got a gsxr400 gk76a model,
have a bit of trouble with it,
basicaly when i pull away from a stop it struggles when going through from bout 2-6000 rpm,
it is ok sometimes if i rev the balls out of it and let the clutch go slightly but that aint too good for my gearbox,
sometimes it just splutters a bit other times it cuts right out! which aint fun when on motorways etc.
it also cuts out when slowing down sometimes but same again if i keep revving a lot is keeps it going,
when it does cut out it will only start when i have the throttle open the full way but will only give about 1.5000 rpm and cuts again once i let the throttle go.
i checked a few posts and it could be the Rectifier? but im not sure
has anybody had similar probs or heard of this happening?
cheers
cheers
Re: bike stalling/jumping at low revs (3-6000rpm)
Carb cleaning needed i think.
carbs have been cleaned recently so should not be them yet,
will give it a go in a few days if i cant find anything else......
anybody know where my airfilter is locaated?
- mattUKNC
My NC sounded very similar when the rectifier packed up. I felt/ acted like fuel starvation but a rectifier and battery later, all is well.
yea, from reading a few posts it sounds like it could be the rectifier as i had the carbs done not too long ago.
how easy/hard is it to change the rectifier and if i change it do i need a new battery too?
if the rectifier is dead wont the lights dim whenm not reving the bike? dont think that is happening!
- mattUKNC
When mine went I tried to keep the bike going as long as I could as thought it was fuel related, I got about 2 miles before everything was dead! The battery was completely fried. So I'm not sure on other symptoms I'm afraid.
To change on an NC30 it's very simple, rear fairings off, 2 bolts, 1 clip connector, job done. The battery is just there too, 1 rubber strap and 2 clamps.
The gsxr might be similar.
:D
Good luck.
Good luck.
cool,
what does a rectifier look like?
also the bike aint dead at all, it runs fine at high revs and cuts out from time to time......still sound like the rectifier?
I don't think it's your rec/reg at all. If it had packed up then your bike would not run and if it didn't blow the main fuse first it would blow the battery.
I still think you need to be looking at the carbs, particularly the O rings and the idle mixtures. Getting the plugs out and checking the colour of them would give you a good idea about what's going on with your fuelling.
Agree with carbs, 3-6k is likely to be o-rings and/or float heights, be worth taking the float bowls off and check all the carbs are set to the same float heights, (had me head scratching for a while
Sorry to jump in oin your thread but what/where is a rectifier and what does it do?
bit new to bikes lol
V
V
