nc23 just died whilst riding now wont even bump start
- Bike owned: cbr400rr nc23 :D
hey my nc23 just died while riding and now cant even get her to bump the lights work but indicators dont and just get a buzzing noise from electric start?
any help massively welcomed!
- thunderace
- Bike owned: R6, YZF600R
Re: nc23 just died whilst riding now wont even bump start
Fucked battery
Check the charging system as soon as you can.
cheers will check it out
- petrolhead19
Get a new battery there only about £25 then check the voltage across the battery make sure it rises to between 13-14v at 5k revs, if its doesnt or is higher then need a new reg/rec
petrolhead19 wrote:Get a new battery there only about £25 then check the voltage across the battery make sure it rises to between 13-14v at 5k revs, if its doesnt or is higher then need a new reg/rec
gonna go get a new one now ill post results up
new battery in she starts fine and idles but then pulling away she dies? its driving me nuts
EDIT: regulator tested at 5k puttin out 13.7v im stumped
- thunderace
How long are you using the choke for? Have you checked the mechanism is moving freely at the carb end?
Like 2 mins full then half for a min and they are fine
- thunderace
So does operating the choke do anything to the idle speed?
Raises it maybe 150-200rpm it idles fine without the choke its just when i pull away it goes about 10ft then dies
