NC35 plug wires
v4hrc
NC35 plug wires
Found my plug wires have been modded by the P.O., any concerns with running wires with NGK caps fitted other than sealing the plug cavity? I guess riding in the rain might let water in the area around the plugs? Are there any aftermarket wires available, or do you have to get the spendy ones from Honda?
Pic:
http://www.rc30.us/images/RVF/wires.jpg
Pic:
- CRM
Re: NC35 plug wires
wonder why they did that ?
cheaper just to buy another coil c/w leads, can pick them up easily and cheaply.
v4hrc
Re: NC35 plug wires
What source and pricing are you seeing on the coils/wires? I'm in the states so that usually adds quite a bit for shipping. I'm guessing the P.O. just threw these on here to get by, I just don't want to have problems due to dodgy wires later on.
Thanks!
Thanks!
- CRM
Re: NC35 plug wires
Here in the UK parts are cheap and readily available as you have guessed.
update your profile location - being in the USA does have quite a significant impact on parts / pricing / availability.
Re: NC35 plug wires
It's worth finding a genuine part to replace it, water and spark plug wells don't mix. It's probably not a case of if, but when it will fill up if you ride in the rain (or wash it).v4hrc wrote:any concerns with running wires with NGK caps fitted other than sealing the plug cavity?
Just post a wanted ad in the classifieds, simple part to post, the beauty of the world wide web.
- speedy231278
Re: NC35 plug wires
I'd not completely agree that parts are cheap in the UK, but DSS can get them, albeit the lead time us up to three weeks. A new set would be about £140 from them, a bit cheaper with CMS at £115.
As someone outside the EU, you'd not pay EU taxes on them, but presumably get hit for whatever import duty the US imposes on such things. I've checked on CMS, and shipped, a set of all four would be 154 Euros, which is about $194. Ouch!
I guess they either work or they don't, although it's not really something I'd like to buy from eBay....
- CRM
Re: NC35 plug wires
to be fair, not many would buy a new one, most would replace with a good used part for a fraction of the new price.
I never meant new parts were cheap in the UK - far from it infact.
Re: NC35 plug wires
+1CRM wrote:to be fair, not many would buy a new one, most would replace with a good used part for a fraction of the new price.
- speedy231278
Re: NC35 plug wires
The issue is telling if the part is good or not
You can get coils from a tenner on eBay, or £15-20 with leads, but how do you know if they're knackered just by looking at them? Also, don't they deteriorate gradually with use? Yes, £30-40 is a lot less than £100+, and I'd probably take a gamble at that price, but if you get stitched up you might end up wishing you'd bought a new one. Having said that, I'm pretty sure I've seen people take the caps off and replace the cable itself with new material. Possibly more effort than it is worth.....
- speedy231278
Re: NC35 plug wires
Sorry to drag this up, but I've just spotted that Rick O does a set of HT leads with NGK caps for £36, check the document library. :-)
