weird charging problem ,found.....
SilverSurfer
hey guys , Well the day started out great sunny weather and such so i got on my nc30 and started her up
then pulled away from the house like a bat out of hell
,all was well until she started to lose power and eventually stalled
. I then proceeded to try and start her up again and heard the solenoid saying "NO-CHANCE", So i called a friend to jump her with a spare battery and she fired up . but when i arrived home and shut her off i decided to try and start her again to check if my battery charged and yet again the solenoid was complaining . after a drink or three i took a tester and jumped her then saw that the reading was at 8,5 volts . I then removed the left hand plastics and stuff , but when i opened the cover on the engine OIL
came rushing out?
So my Question is if that`s normal? (because it doesn`t make sense to me to have oil inside that part of the engine) anyone have any idea why there is oil in there?
- bikemonkey
Re: weird charging problem ,found.....
I take it you removed the generator cover and oil came out?
From my limited knowledge I really don't think that should be happening. Most likely a blown seal somewhere.
SilverSurfer
That`s what i figured and, i almost forgot how the hell do i get the flywheel loose to reach the alternator coils? I`ve been trying but it just turns around even in gear .
- bikemonkey
Alternator coils are attached to the back of the generator cover aren't they?
Plus you need a flywheel puller I think.
- Bike owned: VFR400
Oil under the alternator cover is not an issue, oil from the crankshaft bearing, there is no need for a seal, will drain back into the sump.
A battery with only 8.5 volts is likely to be stuffed. Get the bike started and measure the battery voltage. Should be >13.5 at idle and approx 14.5 at 5000 rpm. if not then start by checking the stator (alternator).
To check the alternator before dis-assembly, unplug the rect/reg and measure the resistance between the three yellow wires, should be <1.0 ohm. If not check the connector located in the V between the cylinders, it may be faulty. Only then would I suspect the stator.
If the stator resistance is ok then measure the voltage between the three yellow wires with the engine running at 5000 rpm, should be approx 50V AC. Do not connect the rect/reg.
SilverSurfer
ok i got the 14mm bolt out but the flywheel ain`t moving what now"?
SilverSurfer
ok thanx alot Magg , i will try that once i get to see what the stater looks like,anyway the 8,5 volts was when i disconected the r/r from the battery and measured it from the r/r output(engine was running on only the battery)
SilverSurfer wrote:ok i got the 14mm bolt out but the flywheel ain`t moving what now"?
Magg is spot on.SilverSurfer wrote:ok thanx alot Magg , i will try that once i get to see what the stater looks like,anyway the 8,5 volts was when i disconected the r/r from the battery and measured it from the r/r output(engine was running on only the battery)
The oil is fine.
Most importantly, you need to test the electrics properly and find your faulty item before replacing parts at random.
After you remove the 14mm bolt you need to screw in an M20 x 1.5 bolt to pop the flywheel off.
Before you get carried away test the electics fully.
Start with the genny.
Fully charge the battery and disconnect the reg/rec plug.
Start the bike and measure the 3 wires with the voltage set to AC on the tester and the engine at 5000rpm.
If you call the 3 wires A B and C
Measure
AB
BC
AC
You should have around 50v AC on all 3 pairs at 5000rpm.
Do this before doing anything and report back.
SilverSurfer
OK ,i did as u said and there is no reading even at higher rpm, what now? but funny enough when i plug in the R/R the output from it is around 8 to 9 volts.
What resistance reading do you get between the three yellow wires with the rect/reg disconnected?
