R6 shocks!
sethbrown
- Bike owned: FZR 400 3tj
R6 shocks!
Hi all, know its quite a common mod but what year r6 rear shock is best to go for? also do any of the r6 forks fit direct to a fzr400 3tj??
- Hogdigerdy Dog
Re: R6 shocks!
a 2006 R6 shock will fit( not sure which years either side of that are the same, but some are) providing you get the adaptor bracket for the bottom mount as the R6 shock is about 24mm to short, or change the dog bones, but the adaptor is the easiest option, have a word with kayal on here she can knock you up either adaptor or dog bones,that's if you can't find a shock that's already adapted on the bay they come up every so often
if you go for it you might wanna put the black spring on it as the standard R6 red jobbie is a bit stiff for the road
sethbrown
Re: R6 shocks!
Thanks for your help mate, I'll start looking.
Any ideas on the forks?
- thunderace
- Bike owned: R6, YZF600R
Re: R6 shocks!
ZX6R F model shock has the right fittings
Taggyd
Re: R6 shocks!
who's kayal?
hehe! she's got some proper nice stuff, you won't have any prob with the kit she makes!
Re: R6 shocks!
You want the later model R6 shock with the red spring.
Early RWU forks will fit but they stick out through the top yoke a long way and I think they touch the mirror brace. That might be ok for a race or track only bike but not good for a road bike. You're better off sorting out the original forks with some new springs and experiment with the spacer length / oil weight, or give them to a suspension company to do.
