Snapped throttle Cable...
Whittmeister
Post by Whittmeister »
Now then!
Not had to post in here so far but there's a first time for everything...
Was out on the bike on Sunday just coming off a roundabout when my throttle cable snapped!
Managed to get it home by removing the housing and pulling the cable and cable tie-ing it in place so it revved to 3k.
Bought a new throttle cable on the bay (it's definitely the PULL one) just awaiting it's arrival.
In the meantime, I have got my tank off and can see the other end of the throttle cable but don't know if I will have to take the side panels off to access it or not? Please can somebody in the know enlighten me :grin:
Also. how difficult is it to do?
Cheers!
bikemonkey
Re: Snapped throttle Cable...
Post by bikemonkey »
You'll need your mid panels off, tank and airbox too. It's quite fiddly so patience is key.
A short 10mm open end spanner is essential.
You'll need to make sure you route the cable properly, and check for adjustment etc.
Have fun ;)
Whittmeister
Legend cheers, thought it looked a bit tight to get my hand between the frame and the cable
Will get the mid panels off tomorrow and hope my new cable arrives.
Appreciate the quick reply ta!
Whittmeister
Right!
Cable arrived today and i fitted it successfully (or so I thought)
Reconnected all the pipes, turned fuel tap back to ON and killswitch ON
Put all the panels back on and it started, wahey!
Ran for about 2 minutes then died, and I noticed my accelerator was slack so I adjusted it and it started again and died after 20 seconds or so.
Not sure what I've done wrong, Is it an airlock or something?
Would appreciate some advise please :grin:
CRM
Admin NWAA
Admin NWAA
Post by CRM »
you put your vacuum pipe on the vent spigot by chance and not the vacuum side lol ? its where my money is.
put the vacuum on the nipple thats the furthest to the right as you sit on it if that makes sense
Whittmeister
Rookie error haha
You sir are a legend!
Saved me a lot of time! Lesson learnt, use masking tape to mark up next time :)
Thanks A lot!
CRM
Admin NWAA
Admin NWAA
Post by CRM »
lol, we have all done it - well nearly all ;-)
Le_Blur
Bike owned: 1990 NC30
Post by Le_Blur »
I did that once and then got a mate to help me run it up and down the road for 10 mins trying to bump start it. Won't make that mistake again in a hurry.
