VFR400 NC30 Idle Screw Replacement
hil21ton
Hi Guys, can anyone help, the idle screw/cable has come lose on my vfr400 nc30 and its no longer attached, the bike will not tick over properly as i cant set the idle speed, the cable looks ok, looks like it needs to be screwed back in, is this an easy job? if so how do i go about doing it?
Re: VFR400 NC30 Idle Screw Replacement
You need to take the tank off and have a look - it is a very simple thing to fit...
hil21ton
Superb thanks, i thought it might be but wasnt sure
hil21ton
All sorted now, idle screw sorted
