trying to remove top yoke..what am i missing??
wedge
right i have taking the centre nut off...the two either side above the bars..even the ignition barrel..open the yokes slightly...it won't budge..hitting it up with a rubber hammer..am i missing one???
Taggyd
Re: trying to remove top yoke..what am i missing??
you have taken the two small ones thatgo into the bars through the yoke (assuming 3tj?)? then the top nut and the two that clamp to the tubes. try slackening the bars and dropping them out of the way and also try turning the wheel to one side then the other, might release things for you while everything is slack. I know on mine it needs to be set dead straight to get them off easily.
Locating bolts on the clip-ons ???
dobbslc
Two bolts under the clipon's pointing up?
Alex.
Ok, someone's got to say it...
Bigger hammer!
Alex.
Bigger hammer!
Alex.
wedge
looks like i been a spaz and not looked at the clip-ons...lol...thanks everyone.
