Chain Slack 15-25mm
Posted: Thu Aug 02, 2012 9:20 pm
I adjusted my chain just before using the correct equipment. Afterwards I measured from the bottom of the chain to the end of the chain slider on the bottom of the swingarm without touching/pushing up the chain and it measures just over 20mm. So as i look at the chain its 20mm away from the end of the slider. Is this correct?
Before i adjusted the chain I could push the chain up with one finger and it touched the slider. Before adjustment the chain measured around 35mm from the slider without being touched.
