Oil Change NC30
james91
Oil Change NC30
Post by james91 »
Hi guys,
Picked up an NC30 second hand recently and it didnt have a manual. Can anyone who has one of these tell me how much oil goes in as well what kind of oil and oil filter to put in?????
CRM
Admin NWAA
Admin NWAA
Re: Oil Change NC30
Post by CRM »
take a look here - all you will ever need
http://www.400greybike.com/docs.htm
james91
Re: Oil Change NC30
Post by james91 »
Thanks but the service manual just tells you to refer to the owners manual when its gets to the oil change part.
Any more ideas?
CRM
Admin NWAA
Admin NWAA
Re: Oil Change NC30
Post by CRM »
well try looking a bit harder - within 2 seconds i found it takes 2.4l at draining, 2.5l at oil and filter change and 3l at rebuild and a 10w40 semi synth is the oil to use. (section 1 - 6)
as for oil filter - well genuine are cheap enough, so why save tuppence on aftermarket ?
want me to come and do it for you too ? :roll:
The Novice
Bike owned: NC23 NC30 CRM250
Re: Oil Change NC30
Post by The Novice »
CRM wrote:want me to come and do it for you too ? :roll:
I need to change the oil in my bike, so come and do mine too if your going to make a day of it.........
CRM
Admin NWAA
Admin NWAA
Re: Oil Change NC30
Post by CRM »
no problem, will fetch a gallon of Nigels hair gel, we can run it on that :grin:
CRM
Admin NWAA
Admin NWAA
Re: Oil Change NC30
Post by CRM »
james91 wrote:Thanks but the service manual just tells you to refer to the owners manual when its gets to the oil change part.
Any more ideas?
your welcome :whistle:
james91
Re: Oil Change NC30
Post by james91 »
Cheers dude
speedy231278
Re: Oil Change NC30
Post by speedy231278 »
Depending on the 'aftermarket' brand, you'll probably find that one of them supplies Honda anyway! ;-)
