nc30 running on 3 cylinders
Posted: Tue Jul 24, 2012 9:03 pm
by j77drs
hi all
bike is running on 3 cylinders, its on of the rears that isnt working,
any ideas ?
i have checked the spark and all is ok
Re: nc30 running on 3 cylinders
Posted: Wed Jul 25, 2012 11:14 am
swap a known working good plug to that cylinder. just becuase it sparks doe snot mean it is healthy enough to run.
Posted: Wed Jul 25, 2012 5:25 pm
by j77drs
plug was also changed,
leads also swapped at coil to check
Posted: Thu Jul 26, 2012 5:57 am
by Lane
Cleaned your carbs lately?
Posted: Thu Jul 26, 2012 4:07 pm
Always running on 3?
If the plugs are clean and dry does it miss just at idle and pick up with revs (slow jet issue)?
Sounds like you have already ruled out plugs though so next would be to investigate the carbs
