NC30 seat lock stuck
Posted: Thu Jul 19, 2012 10:55 pm
by krisztian_andre
I'm losing electrical power intermittently on the bike and I couldn't remove the rear seat to do some checks because the seat lock is stuck, it won't turn at all. How can you get the seat off when that happens, is there a trick to it?
Re: NC30 seat lock stuck
Posted: Thu Jul 19, 2012 11:10 pm
by porndoguk
Try pushing down at the back where the catch is putting a bit of pressure on the seat takes it off the lock making it open far easier
Rick
Posted: Thu Jul 19, 2012 11:56 pm
by krisztian_andre
Tried that, still can't turn the key.
Posted: Fri Jul 20, 2012 9:22 am
by porndoguk
Maybe its seized your only other option is to reach up from under the LHS of the seat panel and pull the release cable, youll need alot of force but it should go.
Posted: Fri Jul 20, 2012 12:30 pm
by krisztian_andre
I almost ripped the whole seat unit apart in anger but I found a relatively easy way to open it.
I couldn't turn the key because (no idea if this is standard or a modification) when I put the seat fairing back on the metal extension on the lock that actuates the cable was inserted into a recess in the subframe about half a cm behind where it should have gone.
The way to unlock it is to remove the 6 seat unit screws on the sides, then remove the two screws under the tail that hold the back light. Then pry up the back corners of the rear seat up with your fingers and unscrew the two screws holding the H-piece in place at an angle. Then where the H-piece meets the back seat you can pry an opening and insert a flat head screwdriver in and push down on the lock mechanism and that's it.
Opening another thread about the electrical problem.
Posted: Fri Jul 20, 2012 3:12 pm
by lizard821000
sounds dead easy that lol
