WATER PUMP LEAK
NC 35 owners
WATER PUMP LEAK
hi guys im new here ..my rvf 400 water pump leak ..its a kind of weird as the leak not much..at water pump behind got small hole the leak come from there..what can i do to solve the problem
- CRM
Re: WATER PUMP LEAK
the seal has failed inside the pump, problem is i dont think the o-ring is listed as a part you can buy either.
if you remove it and cant get it matched, then replace the whole pump with another good used one.
Re: WATER PUMP LEAK
buy a new waterpump.
As crm has said it isnt servicable. it will eventually sieze and snap (had it happened beofre)
the Honda book says to replace also..
NC 35 owners
Re: WATER PUMP LEAK
I when to bike shop they say it's can be repair ..I did it my self once and I change the o-ring that going inside the engine and the gasket between the pump but it's still the same leak again
Re: WATER PUMP LEAK
It can be repaired on some bikes..but not this one.
Easier and cheaper to get a decent pump and replace it in one go. Easy.
- petrolhead19
Re: WATER PUMP LEAK
Same thing with my srad leaking from the little hole. its the mechanical seal which is buggered on mine just waiting for the part to come cost £14 for a tiny seal lol
NC 35 owners
Re: WATER PUMP LEAK
thanks buddy for all the info..will get a new one ..
Re: WATER PUMP LEAK
that o-ring stops the oil from leaking out the engine.. it doesn:t stop the water.NC 35 owners wrote:I when to bike shop they say it's can be repair ..I did it my self once and I change the o-ring that going inside the engine and the gasket between the pump but it's still the same leak again
the water pump o-ring on the nc30 is inside the waterpump you cannot get out
I brought 2nd hand pump from good bike for cheap, it was in very good condition and still works good now.
NC 35 owners
Re: WATER PUMP LEAK
thanks buddy for that great info..in here it's a kind difficult to get 2nd parts and new parts really cost
boom..any places that I can shop in a good cost
NC 35 owners
Re: WATER PUMP LEAK
hey guys I did change water pump to new one and it's work great..thanks go the best info from you guys
