Ignitech - Does it negate the speedo restriction?
Hey all,
I spent a day at the track tuning my carbs yesterday and have an apparent lose of power at the top end. I think it is because my mains are too small, but looking at the logged top speed, and it never goes above 180kph, which coincidentally is the speed restriction limit!
The only other change I made is swapping the CDI to an Ignitech as the OE one blew and so I also removed the resistor mod as I seem to recall you not needing it. Is this correct?
Just want to cover all bases before ordering jets!
Luke
Luke
Re: Ignitech - Does it negate the speedo restriction?
I should also add that the unit is running the updated maps that fix the top end power loss!
yes ignitechs dont require de restricting nore do they restrict it
no restriction on the ignitechs.
