NC30 camshaft timing check
krisztian_andre
- Bike owned: MG v35 II, NC30, MG NF Mil.
I have a slight suspicion that my front camshafts have been installed 1 tooth off from the correct position. The procedure in the manual is to set the camshaft mark to the mark on the camshaft holder and to set the T2 mark on the crank to the mark on the crankcase cover but the nut appearing in the timing hole does not look to be at the centre of the hole and the alignment of the T2 mark to the cover mark is difficult to judge precisely since it is different depending on the angle you look at it. One tooth difference on the camshaft gear (40 teeth) would mean only 4.5 degrees difference on the crank.
Is there any other way to check if the camshafts are installed in the correct position?
scotjell
- Bike owned: VFR400 NC30x2
Re: NC30 camshaft timing check
If I remember with the rocker covers off you can see the positions of the markers. look to see if the positioning is the same on each after a full cycle if you know what i mean? I think you'd also know if you was out by a tooth as would sound a bit rough. If and when you take the cam gear off just be careful when tightening down do it evenly don't force them down.
krisztian_andre
I'm not sure, what do you mean exactly?
what makes you think it is out? does it not run? is it just an angle thing from your view of the timing marks?
scotjell
sorry about this,
please slap my wrist if I'm out of order.
Also you may think 4-5 degrees isn't a lot but once extended through a length it's quite large. The haynes is good for this can't go wrong. If you want more images please email me.
krisztian_andre
Ah I think I know what you mean. Comparing the two heads camshaft mark alignments. I'll try that thank you.scotjell wrote:sorry about this,
Last edited by krisztian_andre on Mon Jul 09, 2012 7:47 pm, edited 1 time in total.
krisztian_andre
Besides the angle thing, it does not run well and the front heads' valve clearances are close to zero for the intake and 0.4mm for the exhaust valves whereas on the rear head they are consistently much closer to tolerance and the timing mark alignments look good.CMSMJ1 wrote:what makes you think it is out? does it not run? is it just an angle thing from your view of the timing marks?
Last edited by krisztian_andre on Mon Jul 09, 2012 8:08 pm, edited 1 time in total.
scotjell
Well if you go through the sequence on one head doing the inlet and exhaust use a marker pen and mark the head. then when you do the other one you'll be able to tell if the angle is the same. If not then the cams could be out. Hope this helps.
lukemillar
It's actually 9 degrees as the crank will rotate twice for a single cam rotation.krisztian_andre wrote:I have a slight suspicion that my front camshafts have been installed 1 tooth off from the correct position. The procedure in the manual is to set the camshaft mark to the mark on the camshaft holder and to set the T2 mark on the crank to the mark on the crankcase cover but the nut appearing in the timing hole does not look to be at the centre of the hole and the alignment of the T2 mark to the cover mark is difficult to judge precisely since it is different depending on the angle you look at it. One tooth difference on the camshaft gear (40 teeth) would mean only 4.5 degrees difference on the crank.
- Lane
- Bike owned: MC21,MC22,NC35's,VJ22
The slight difference you may encounter due to parallax error on the timing mark on the crank, is minor compared to if you put the cams in one tooth out, it should be obvious when you have it right.
If in doubt, remove the other cam cover, align it's cams with the marker, then note the cranks alignment marking with the T1, use that evindence to line it up for the front.
