How are you all restraining your braided lines?
- jetblack
- Bike owned: '89 NC30 SEED
I've fitted braded lines recently but as they have a smaller diameter than the stock lines, the standard hose guide is no good.
So, how are you all tying your braided lines out of the way?
I've got a zip tie on there at the moment but it is a little unsightly and i'm worried about it rubbing through the lines.
- thunderace
- Bike owned: R6, YZF600R
Re: How are you all restraining your braided lines?
I normally replace the OE bracket with rubber lined P clips, stainless ones. Cheap enough and they have an M6 mounting hole. Perfect
Pliers.....pinch the original holder.....
Cable tie
- Bike owned: 1990 NC30
Yep thats what I used for the front and used the original rubber grommet type things for the rear, just squeezed the clips a bit to secure them, didn't look that great but works. You can, I believe, drill holes in the swing arm front and rear and thread the hose through. Personally I couldn't be arsed with that but I'm sure it looks betterporndoguk wrote:Cable tie
