Leaking reserve sensor
Posted: Mon Jul 02, 2012 10:13 pm
Hi -
I've changed fuel tanks on a 3tj as the old one was too rusty inside and have had to put the reserve sensor from the old tank into the new one - it has a little rubber gasket in it but it leaks even tho it's as tight as it'll go - do I need to use a gasket sealer and can anyone recommend one that will stop it leaking or do I need to get a new rubber seal?
Also something that's baffling me - I used to own this bike about 7/8 years ago and it started normally back then, how they should - since I've bought it back again it won't start unless the clutch is in and the sidestand up? Bit of a pain with this as if I want to keep the bike running but leave it on the stand then it cuts out?!!
It also now has no Neutral light and it's not the bulb - could that be due to the above too?
I can't ask the guy I sold it to originally what he's done as he was involved in a car accident (only about 6 months after I sold him it) and is still in hospital severley brain damaged to this day
Any advice much appreciated - ta
