XJR 400 rear wheel
				G3o
XJR 400 rear wheel
Had a search but did turn anything up, I'm 99% sure i've read the rear wheel from an xjr 400 will fit the fzr? Has anyone done the conversion on a 3en1?
If so is it just a direct swap of just the wheel or do you need the spindle, spacers and rear break assy too?
Ta,
Geo
Ta,
Geo
				bubbadel
Re: XJR 400 rear wheel
you will also need the rear brake caliper and arm as the disc is the same as an fzr600, so you can use the 600 caliper/arm too, i know because i want one too, but i already have the 600 rear wheel etc on my bike. you will also need to change the dog bones on the suspension linkage as the rear will be lower
				G3o
Fantastic thanks a lot :) just picked up a rear wheel and break assy up on evilbay for 100 quid :)
