NC24 Side panel fixing bolt
Harrismag
Hi,
At present my side panels are not fixed onto the frame at the bottom (cable ties for now). From the plate on the frame it does not look as if its a bolt / screw that holds them on?. Where can I get a set of these fittings and what are they plastic?.
I hope this makes sense.
Cheers Harrismag
Cheers Harrismag
castrol101
Re: NC24 Side panel fixing bolt
I would get in touch with a honda dealer and explain to them what you want,
There about £6 when i ordered one, but i can't remember what they are actually called lol.
Try david silver
since im nice i dug the parts manual out.
the bolt is 4 parts
83703-ml0-720 - bolt
17516-383-670 - spring
94101-10000 - washer
94305-20183 - pin
dave silvers have it, back order from honda
the bolt is 4 parts
94305-20183 - pin
Harrismag
Cheers Neosophist for the info, I will check it out today. Tonight I have the thrilling job of taking the cards off, its going to be fun.
