Won't idle right after carbs o ring change
Zemon
Post by Zemon »
It's a gk76a
We just took carbs off, done the o rings, re fitted, bump started but she idles at almost 0 whilst running and dies after a 30 seconds. We adjusted screws at 1.5. It looks like an sp but the carbs don't. We are Gona try 1.8
Any other ideas
I'll pop a video up in a sec
We did take it for a run but got told off by police lol
Jaicen
Bike owned: GK76SP & ER6F
Re: Won't idle right after carbs o ring change
Post by Jaicen »
Awesome!
Can you get us some pics of the carbs? What year is the bike?
Will it idle with the choke on, or does that cause it to flood?
I think you've possibly pinched one or more of the main jet O-rings, which lets fuel flood the cylinders and fouls the plugs. Run it till it stops, then pull your plugs and see if they're wet, then get back to us.
Zemon
Post by Zemon »
We adjusted screws to 1.8 an it runs better. I think it was running Lean. It doesn't cut out now but still not right. turned it up more and it started to smooth out a little, still not right but stank of fuel from exhaust.
We did note that the screws were all at different positions when we removed carbs
Zemon
Post by Zemon »
It's a 1990 it has an sp body and we think it I an sp but not 100%
Choke isn't the issue I don't think
Video:http://i1172.photobucket.com/albums/r56 ... 92ed28.mp4
These are the carbs Image
Although it doesn't cut out now I changed to 1.8 turns
Marsbar
Post by Marsbar »
oh its on a car lol :/ your jetting and needle height will need to be changed, best taking it to a dyno for A/F mixture graph.
Zemon
Post by Zemon »
A car??? It's a gsxr 400 lol
Marsbar
Post by Marsbar »
you posted the wrong vid then :/ but a dyno graph works wonders anyway
Zemon
Post by Zemon »
Doh
Here is The right one:http://i1172.photobucket.com/albums/r56 ... 373e65.mp4
Anyone know what connects here:Image
And what this connects too ( pipe running across left to right, comes from carbs but where should it go ) :
Also the plugs were black an he adjusted them to a figure he found online but sounded like it was Gona go bang. Anyone know The correct gap size??
Also any ideas if it's sp or not an sp model??
Dave
rgvsp
Bike owned: RGV250SP (VJ23) GSX-R400R
Post by rgvsp »
Looks like a standard GK76. Carbs look to be standard (no tps) and forks don't have the SP adjustments.
The picture of your tanks is for a drain/overflow (not sure of function) but a hose should run down to the mid pipe. There are two other hoses there as well.
The hose on the carb looks to be one of the hoses that should run back and clip onto the air box. It vents to the atmosphere, doesn't connect to anything.
Jaicen
Post by Jaicen »
I asked about the choke, because if you can start the bike without choke, your o-rings are probably leaking.
Given that the plugs are black, it's definitely running rich, so I'd be looking at the carbs again.
Have you had it running before the carb strip down?
