NC35 refitted cleaned carbs.... fuel leaking out of overflow
GFRacingUK
ok, i finally got the carbs back on tonight, connected up a remote gravity fed fuel tank (not the bikes tank ) connected it to the main fuel hose, and theres fuel overflowing out of the 2 top carb overflow pipes, and what sounds like into the inlets.... what have I done wrong? and im guessing the carbs are gonna need removing and opening up again!?!
GF Racing UK - New & Used Parts CBR400 NC23/NC29/VFR & RVF400 NC30/ NC35
Contact: Dan Marsden or Graeme France
http://www.gfracinguk.com
sales@gfracinguk.com
Tel: 01652 650142 -
Ext 1 for Parts - Dan
Ext 2 for Workshop - Graeme
Tel: 01652 650142 -
hardnutdvd
- Bike owned: RVF400 NC35
Re: NC35 refitted cleaned carbs.... fuel leaking out of over
i have no idea if it makes a difference from proper tank or gravity fed tank.. but i have read that the floats can stick, causing fuel to overflow. or improperly set float height...
if their sticking a gentle tap on the carbs can sometime sort it...
there is also a good template you can make using a credit card to set the float heights to correct setting on here too.
saying all this, i am by no means an expert. just repeating what i have learnt on here.
amaechizzle
- Bike owned: NC35
+1
If you havent thrown your float heights way out, sometimes they stick when your putting them back together.
Either a soft tap with a rubber mallot is worth a try, or pull it all back out and refit it again.
Last time it happened to me, my back two cylinders compression locked on start up after putting everything back together.
- vfrman
- Bike owned: NC30, 1098s
What they said. It is a float.
GFRacingUK
Thanks guys, that makes sense, after further investigation, number 2 cylinder is full of fuel.... awesome!
whats the best thing to do? I can stick a syringe down with a tube on and get most of the fuel outo of the inlet tract, but Im guessing the cylinder will also be full, if the valves are partially open? Do I need to hand turn the engine over with the plugs out, and then use the syringe down the plug hole?
Tel: 01652 650142 -
Tel: 01652 650142 -
- vfrman
If you have a cyl full of fuel, you need to get the oil changed out as well. The fuel will move past the rings and dilute the oil....don't ask me how I know!
hardnutdvd
lmao vfrman... just seen your sig...
i wrote off my r125 on a head on collision with a 2010 model Audi s4 in 2009
- vfrman
Yeah....I didn't edit that! I also like how it lines up with the earlier statement about not needing a rear brake...
GFRacingUK
good advice, I was gonna do an oil change anyhow, Im just glad I didnt do it prior to this carb issue!
Tel: 01652 650142 -
Tel: 01652 650142 -
lizard821000
i had the same proble mate, i tapped all the carbs with a rubber mallet n screw driver and it stopped the overflow....... and prob had a sticky shut of valve too, sorted with a general tapping .
i used an auxilry tank too, gravity feed. i feared i most likely flooded a cylinder, i just run it up to clear it out lol am i fk taking her apart again to remove the buried plugs on these things!! lol
