Suspension again
wambam87
Suspension again
Hi guys ,
Recently now the bike is up and running ( like a dream ) , Ive been pushing it a little more , but ive started to bottom out the suspension under braking and if i hit larger bumps in the road.
Ive heard / read about the rick oliver kit and have emailed him ( as i weigh 90kg's hes said he can source some rellevant springs for me) but would it be worth pulling apart the forks to see if ive got any oil in em at all. As i can brake and brake then all of a sudden they just bottom out? Also , ive wound the pre-load in till theres 2 notches showing and 7 clicks round on the rebound.
Do i have poorly forks ?
Any help would rock
Any help would rock
Re: Suspension again
Its common pal, id only have to go up my drive from the road and id bottom out, new oil, new rick oliver springs sorted it well worth it.wambam87 wrote:Hi guys ,
Any help would rock
wambam87
awsome thanks , Payday soon so il get some springs orderd , random question but what oil do i need ?
- Deviant400
if you buy the rick oliver kit , he sends you springs , oil a syringe for measuring and a little guide on what to do
viewtopic.php?f=62&t=27307
h2o-pro
Rick sourced me some 90kg front springs with his kit... The front end is now in a different place !
My bike is used for the track...for sag set up you only need a couple of turns of preload... I still get plenty of travel too...just throw on a couple of cable ties and see where you are at.
I used 10W oil... but damping is up to you & the way you ride...If you can't get it right just start mixing !!
While those forks are off put new seals & bushes in !
+1 on the cable ties just dont put them on too tight
