turns off then 5 min later starts fine
vfr400aussie
Hi i hope someone can tell me where to start looking
but i was at the track today after the second session nearly back at my pit box it just turned off so i stoped tried to start and nothing at al didnt even turn over.
anyway 5 min later starts fine
so go down to the grid for the first race and off the line fine go to change gear then stops again, clutch in dump it nothing, so get to the side of the track and nothing wont turn over. but end of race starts fine and ride back to the pits.
and then the next race same thing again except it cut out when i lined up on grid
so can anyone please help
- Bike owned: VFR400
Re: turns off then 5 min later starts fine
Sounds like a loss of battery power. Suggest you start with a check of the +ve and -ve battery connections. Then follow the leads from the battery to the frame and starter relay. Make sure the lug nut/bolts are tight. Check the main fuse, in the start relay unit, has clean & tight connection.
vfr400aussie
cheers will do i was thinking hopefully something easy like that i will clean all the connections and see what happens next weekend
