NC30 Air flow improvement
james91
Hi All,
Just a quick one, ive read some things on the net that suggest that if you cut a hole in the plastic peice above the radiator just behind the steering head [just in front of the airbox snout] the engine will draw in cooler cleaner air rather than hot air from underneath the fuel tank. Question is- Has anyone tried this? And does it affect the delicate airfuel balancing that goes on in the carbs meaning they will need tuning to compensate for different airflow?
Re: NC30 Air flow improvement
Have a search...but the bottom line - the engine needs cool still air. not turbulent air.
My take on it - leave it standard. It works..and any benefit is not worth it - the bike won't suddenly get another 5hp...
Most NCs hate some, like my freaky thing is currently in the experimental stage if trying different things with the air flow
lizard821000
i thought the air was sucked in behind the forks, under the frame head stock!?
