Jetting recommendations
Posted: Sun Sep 14, 2008 8:52 am
by Riley
Hope someone can help, I'm after some decent base settings for my bike before it goes off to the dyno. First off it's an nc30 with a foam washable filter, vfr carbs with the drilled slides and raised needles, and an ethos half system with freshly bead blasted standard headers. Otherwise standard. Any help appreciated, I assume I'll need to contact Rick Oliver to get the correct jets, cheers Paul.
Re: Jetting recommendations
Posted: Sun Sep 14, 2008 10:47 am
You will be looking at the classic 118 F and 120 R setup mate.
As long as your airbox is standard too..
Posted: Sun Sep 14, 2008 4:28 pm
by royster81
rised needles and drilled slides will make it very rich low down,maybe you could lower the needles back to stock 0.5mm and 118/120 jets for a good fair start.
i'd be very interested to hear the out come but.
