Headlights!
- Sam-NI
- Bike owned: '89 VFR400
Headlights!
I have done the relay mod, and installed 2 UK spec 60/55w
My headlight alignment is way out!
Is there only 2 adjustment screws per side on the NC30?
MOT is Friday evening, so need some help ASAP!
- Deviant400
Re: Headlights!
yes 2 screws on each light one at the top and opposite bottom corner i belive
viewtopic.php?f=62&t=27307
Re: Headlights!
How did you make the bulbs fit?Sam-NI wrote:I have done the relay mod, and installed 2 UK spec 60/55w
Did you use adapter rings?
Did you cut the piece of tab away and alter the lower tabs to make them fit right?
- Sam-NI
Re: Headlights!
I just bent the lower 2 tabs in. What should I be doing?
Re: Headlights!
Oh then it'll never line up!Sam-NI wrote:I just bent the lower 2 tabs in. What should I be doing?
Unless your using adapter rings then You need to cut some of the bulb and use a nail to support the bulb, otherwise it won't line up right.
http://cbr250.com/forum/thread-284.html
Here is the nail guide.
You'll notice that theres a cutout in the outer ring of the original H4R (35w) bulb too. the H4 doesn't have this I filed down the indent on the inside of the headlight as it's easier than cutting the bulb.
