BAD STARTING
				sarge-1974
BAD STARTING
Hi ive got a fzr 400 exup with a starting fault.the bike been parked up for 18 months,i put fresh fuel in drained the carbs, fuel pump is working but the only way i can get it to fire is with a spray of easy start.once running its fine ticks over revs up fine.i can turn it off and it will fire up again fine,if i leave it for a day i got the same fault again   can anyone help
 can anyone help
thanks sarge
						 can anyone help
 can anyone help thanks sarge
				Clanky
- Bike owned: FZR 400 3EN1, FZR 600 3HE
Re: BAD STARTING
If you aren't already doing it try turning the fuel tap to the 'off' position when not in use and see if that helps.
				dobbslc
Re: BAD STARTING
You could try some new plugs as they go off over time when sat in a damp motor.
Re: BAD STARTING
Clean the carbs, renew the fuel filter and plugs - if it doesn't help then it's probably the valve clearances need doing.
