Shock fitting with pics
Tomzed
- Bike owned: Yamaha wr125x and Nc30
Can anybody tell me if this is normal or have nitron built my shock with the wrong end the bolt is not tight
And a close up there's a gap where it bolts to the linkage
lukemillar
Re: Shock fitting with pics
Never really looked at it off the bike, but I think my Ohlins has some lateral movement. I just measured the distance between the inside of the rear shock mount for comparison and the Ohlins is 30mm.
Tomzed
Just measured it and it's 32mm wide
nazzurro_19
- Bike owned: Honda NC30
Is it not slightly loose so it acts like a pivot/rebound if you get me
Tomzed
I'm unsure it may be supposed to be like that but as its my first nc30 I thought I'd check before everything is bolted in place
GFRacingUK
Im just about to fit the same road nitron shock to my nc35 tonight, i'll let you know if i have the same problem
GF Racing UK - New & Used Parts CBR400 NC23/NC29/VFR & RVF400 NC30/ NC35
Contact: Dan Marsden or Graeme France
http://www.gfracinguk.com
sales@gfracinguk.com
Tel: 01652 650142 -
Ext 1 for Parts - Dan
Ext 2 for Workshop - Graeme
Tel: 01652 650142 -
MickCheese
- Bike owned: ZXR400, 954 Blade, NC30
Be careful. I have one on the shelf in my garage that I will measure for you a bit later.
There was a craze a few years ago of fitting a Aprillia RS250 shock, in order to do that you needed to shave that part of the linkage down.
Did it have a standard shock fitted?
Edit - Just measured the bush, it's 30mm. That suggests your Nitron has the wrong fork fitted.
Mick
Mick
lizard821000
use a shorter bolt!? or add washers if your really pikey.
Tomzed
It's brand new hence just finding out if they have just put the wrong end on. A shorter bolt will make no difference as its the u part at the bottom of the shock that seems to be too wide
lizard821000
i see, didnt look closely, just use some washer/shims to space it out.
