NC29 carburetor vacuum pipes.
- leopard_pagan
i am looking to replace mine on the NC29-L
i have the fishes etc (2 of them) but not sure which pipes i need, just been told they are rubber?
if you know, can you just tell me the numbers?
- Davez29
- Bike owned: NC29 forever
Re: NC29 carburetor vacuum pipes.
The covers are rubber with tiny circlips. The pipes are brass.. Sorry cant get the numbers now as im on my phone but if you dont get sorted i will look em up tomorrow. Number 1 cylinder is the hardest to sort, unless you have tiny hands.
- leopard_pagan
Number 1cyl far left? If so that's the one I start on when I change plugs & yes got small hands :0)
Brains out the gutter boys!!!
- Davez29
After looking at your pics on a proper pc, I think I may have the wrong bits in mind, unsure?
Are they the vacuum tubes you use when you balance your carbs?
So for now I will assume this is what your after.
If so here is what you need X4
Cap boost.. 16215MV4000 ..Rubber caps
Joint boost.. 16214MB0000 .. brass valves
Clip B7.. 9500202070 ..clips for cap boost
These can be found on the cylinder head part of the fiche. DS has them in stock as I replaced some a while back.
If its not those, sorry dont know, eleborate please.
dave
dave
- leopard_pagan
was in passing conversation about my running issue. it wont run smooth under 20mph.. "airs getting in" so i am replacing the head rubbers (between carb n head), but someone said dont forget the vacuum pipes as they can crack/leak in air too... as i cant quite see which is a vacuum rubber & what isnt.. thought id ask here
BUT after more searching, i THINK the vacuum pipe is the one leading from the carbs to that silly sub air filter that sits under the air box...
- Davez29
Ahh.. in that case there is a good possibility he means those cap boost covers mentioned by me above. They maybe are perished letting air in directly to the cylinder. pull em off and check but be careful as a couple of mine were lightly perished and then came apart while trying to take the pesky circlips off. They are not too much at £1.55 before vat/delivery, but only 8 in stock at DS, maybe GF stocks them as well.
- leopard_pagan
id get them before i do any work to it as can not have bike off the road at any stage.
- Davez29
Yes thats the problem i always have. Got to do everything between shifts; its a pain. Im still trying to find the time to put my new genny reg/rec and pulse coil on. i need a second bike really.
- leopard_pagan
genny was easy. i did mine last year. took a couple of hours.. hardest (took longest) part was cleaning the old side gaskets off.
reg/rec is plug n play job.
not fitted the last one.. yet
- leopard_pagan
got the rubber caps on order.
