brake pressure switch
hardnutdvd
- Bike owned: RVF400 NC35
i bought a brake pressure switch to install onto a set of aftermarket rearsets..
when i got home and took it out the packet, it is not the type that bolts into the top of the mastercylinder.
the end is similar to that of a brake hose. round hoop with small hole
it installs the same way as the brake hose.. either above or below the brake hose fitment..
i'm guessing this type wont work as there is only one hole at the top of the bolt that screws into the mastercyclinder??
- vfrman
- Bike owned: NC30, 1098s
Re: brake pressure switch
From what you describe I would think you need a double banjo bolt to go along with that switch...
hardnutdvd
thats what i thought.
my own fault for being impatient. i know i coulda got one off ebay, but i rang a local motorbike shop and took it away in a bag without looking at it until yesterday.
If you've converted the fronts to braided and still have the original Honda parts, theres a double banjo bolt that goes through the splitter I believe.hardnutdvd wrote:thats what i thought.
hardnutdvd
got myself a double banjo bolt on way home from work but still useless... lol.
the spacings of the holes on the double banjo are for 2 brake lines (obviously)
but this fitent on this brake switch i bought is a lot thinner. so doesn't line up with the second hole! i weren't gonna risk leaks by packing out with 6 washers. id rather do it properly once and save the hassle or worry...
i given up and contacted gav at jap 4 to hopefully post me a 'normal' pressure switch out tomorrow...
lesson learnt though i suppose :)
- Deviant400
this is the puppy you need mate
http://www.ebay.co.uk/itm/Brake-pressur ... 3cc3761369
viewtopic.php?f=62&t=27307
hardnutdvd
yeah i got your link in the PM too...
i was being a smart arse and rushing to get one locally rather than waiting
my own fault, i didnt even look at it until it came time to fit
ended up with this..
- vfrman
Ok, that isn't what I pictured in my mind at all. Is that supposed to replace the top washer to the banjo?
