Setting headlights - NC30
Posted: Sun May 27, 2012 11:58 am
by hannakournikova
I cant recall where, but im sure i seen a quick reference for roughly setting headlight. EG bike on flat 3 metres from wall and should be hitting at a certain height and certain shape. Anyone??
Re: Setting headlights - NC30
Posted: Sun May 27, 2012 1:23 pm
by hannakournikova
for reference:
Motorcycle Headlight Aiming
Getting a correctly aimed headlight is straightforward. You need to make a couple of measurements and then aim the light at a flat wall, as follows:
With the bike on its wheels and you astride, have a helper measure the distance from the floor to the center of the headlight lens.
Pick a flat wall where you can locate the bike so the headlight is 17 feet from the wall. Place a horizontal mark on the wall two (2) inches lower than the height of the center of the headlight.
The headlight beam (on low beam) should be relatively flat on the top, and may rise rather sharply at the right edge. Adjust the headlight vertically so that the flat top of the beam is just up to that line (marked two inches down at 17 feet).
Horizontal adjustment should center the beam ahead of the line of the bike.
Posted: Mon May 28, 2012 10:08 am
by Sam-NI
Was just about too look this up! MOT tomorrow! Is yours due soon Chris?
Posted: Mon May 28, 2012 11:45 am
by hannakournikova
Yes Sam, MOT on Wed lol
Hows your bike getting? Anytime your free call up for a chat and a coffee :)
Posted: Mon May 28, 2012 11:52 am
by Sam-NI
MOT Tomorrow! Could be grim! No lower rad fan, (got the loan of one off Rhory, but getting one possibly off another guy, but wont get fitted for then). Also need to check REC/REG isnt toast tonight, and might be getting a replacement one tonight too! And my MOT is straight after work tomorrow, so could be a busy boy tonight!
Posted: Mon May 28, 2012 12:37 pm
by hannakournikova
hahaha no rest for the wicked. Hope Rhory didnt give you my rad fan and bracket :P because he cant seem to remember where he put it :/
Posted: Mon May 28, 2012 1:02 pm
by Deviant400
its in the back of the haynes , pre mot hecks
Posted: Wed May 30, 2012 9:57 am
by Sam-NI
Didn't get round to doing this, had charging issues that needed sorted. Guess what it failed the MOT on??
