Setting headlights - NC30
- hannakournikova
I cant recall where, but im sure i seen a quick reference for roughly setting headlight. EG bike on flat 3 metres from wall and should be hitting at a certain height and certain shape. Anyone??
- hannakournikova
Re: Setting headlights - NC30
for reference:
Motorcycle Headlight Aiming
Getting a correctly aimed headlight is straightforward. You need to make a couple of measurements and then aim the light at a flat wall, as follows:
With the bike on its wheels and you astride, have a helper measure the distance from the floor to the center of the headlight lens.
Pick a flat wall where you can locate the bike so the headlight is 17 feet from the wall. Place a horizontal mark on the wall two (2) inches lower than the height of the center of the headlight.
The headlight beam (on low beam) should be relatively flat on the top, and may rise rather sharply at the right edge. Adjust the headlight vertically so that the flat top of the beam is just up to that line (marked two inches down at 17 feet).
Horizontal adjustment should center the beam ahead of the line of the bike.
- Sam-NI
- Bike owned: '89 VFR400
Was just about too look this up! MOT tomorrow! Is yours due soon Chris?
- hannakournikova
Yes Sam, MOT on Wed lol
Hows your bike getting? Anytime your free call up for a chat and a coffee :)
- Sam-NI
MOT Tomorrow! Could be grim! No lower rad fan, (got the loan of one off Rhory, but getting one possibly off another guy, but wont get fitted for then). Also need to check REC/REG isnt toast tonight, and might be getting a replacement one tonight too! And my MOT is straight after work tomorrow, so could be a busy boy tonight!
- hannakournikova
hahaha no rest for the wicked. Hope Rhory didnt give you my rad fan and bracket
because he cant seem to remember where he put it :/
- Deviant400
its in the back of the haynes , pre mot hecks
viewtopic.php?f=62&t=27307
- Sam-NI
Didn't get round to doing this, had charging issues that needed sorted. Guess what it failed the MOT on??
