anodized carburetor...
garyboy_palaboy
Have anyone tried anodizing their carburetors here?
I have a plan to disassemble the entire carburetor assembly and get the whole body and covers anodized (not including the jets, internal parts, etc.). Will it have any effect on the carbs performance?
Im planning to get a new set of carb gaskets if this will work.
Anyone want to share their opinions?
Thanks!
Thanks!
lizard821000
garyboy_palaboy
Re: anodized carburetor...
i hate how my carb looks from outside, looks dirty to me. it works well but sometime i hate seeing it.
- thunderace
- Bike owned: R6, YZF600R
Try cleaning them properly then - in a solvent bath. Ultrasonic is a waste of money.
cbr400rrn
- Bike owned: NC29 CBR600F
thunderace wrote: Ultrasonic is a waste of money.
- leopard_pagan
erm.. bit extreme if you ask me.. i can hardly SEE my carbs from under the tank, or the side.
why dont you spend the time and money on say the power output, suspension set up or brakes... than how the carbs look on the out side!
vr46
- Bike owned: All sorts
I suppose you could fabricate carbon fiber or CF Kevlar mix cosmetic covers?
Skint Novice F400
lizard821000
just have the things cleaned.
dogmatic69
- Bike owned: RVF400 RGV250
Worked quite well for me, got them spotless whilst watching the tellythunderace wrote:Ultrasonic is a waste of money.
As for the anodising, due to the nature of the process some (possibly tiny unimportant amounts) metal will be removed. Normally in the range of microns.
One advantage is the process chemically seals the aluminium so it wont corrode. Besides that I would not bother as you cant see them anyway
amorti
- Bike owned: CB-1, MSX125
I wouldn't say that... here's something from another forum I frequent.thunderace wrote:Try cleaning them properly then - in a solvent bath. Ultrasonic is a waste of money.
http://www.customfighters.com/forums/sh ... hp?t=57367
Before:
After:
I wouldn't fancy anodising them, that'll be on the inside too and there are parts with extremely fine tolerances there. In any case, you're going to need them very well cleaned before treating.
