92 CB400 SuperFour - Restrictor kit help please!
Imp
Bike owned: RV125, CB400 Super Four
Post by Imp »
Hi, I'm new here but have always loved all things Japanese and had my heart set on a Jap 400 as my first big bike.
So i've succeeded and now am the proud owner of a lovely 1992 CB400 Super Four :grin:
BUT I neglected to make sure first that I could get a restrictor kit for it (other things i'd looked at you could easily get restrictor washers on ebay for £40 or so). So, um, is there any other way of doing this? Are there any from other bikes that would fit? Or does anyone know the dimensions for the washers and I could see about getting some made? I don't really want to have to pay the stupid dealer prices for one of the F1 thingies :pray:
RICKNC31
Re: 92 CB400 SuperFour - Restrictor kit help please!
Post by RICKNC31 »
Hi there is a posting on the workshop section about the restriction washer size i belive it was about 36mm washer with a 18mm hole in the center but better check back to be shure and these fit in the inlet rubber tubes to the engine. All the best rick
Thomas
Bike owned: Gpz900r
Post by Thomas »
Hi, I have just been in talks with the bloke who makes the 33BHP kits on ebay for £40 or whatever,
It turns out the cbr400 NC29 kit is a perfect fit. (I enquired about it fitting to a 1993 model 'Big one') ;)
http://www.ebay.co.uk/itm/Honda-CBR-400 ... 874wt_1397
:rocks:
Imp
Post by Imp »
See thats odd, because I sent a message to the same guy asking exactly that (if the CBR400 kit would fit) and he sent this response:
"I'm having trouble matching a kit up I'm afraid.
your carbs are 32 mm and all the 400 Honda kits I have are for 26, 28 and 34mm carbs so they won't fit as far as I know.
I'd be more than happy to send you a couple of kits to try, they all make around the same amount of power so the level of restriction is easy to guess, it's just the actual fitting size which will be a bit of trial and error.
now I've said that, the nc29 kit is probably the one to go for as it will be a touch small rather than too big, so at least it should fit ..."
I have also seen these dimensions given online for an F1 restrictor kit for a CB400. So now i'm totally confused...
"Device: Blade
Device Code: B2-NC31-K25
Device Details and Dimensions:
Outer Diameter = 38mm
Inner Diameter 1 = 17.3mm
Inner Diameter 2 = 13mm "
I'm guessing the only option might be to take the bike apart to measure the carbs to be sure but I was kind of hoping to only have to do that once i'm not super-mechanically minded!
Thomas
Bike owned: Gpz900r
Post by Thomas »
I told the guy about the dimensions that had already been posted on here which were (36.5 Outer diameter with a 18mm Inner diameter)
I told him this "I dont have the bike yet, but its a 1993 model 'Project big one'
I don't know if its helpful or not but apparently the dimensions for the washers are 36.5mm Outer diameter and 18mm inside diameter, This is only what i have read though so im not sure if it is right or now.. "
This was his response;
"hi again, it looks like an identical set up to the NC29 so that's the kit for you when you get the bike!
regards, mark"
If i get the 400 that im watching i will get the NC29 kit and see what's what..
Thomas
Bike owned: Gpz900r
Post by Thomas »
Okay, 5 mins of resarching.. I have come up with this.
Both the CBR NC29 and the CB NC31 have 32mm carbs..
Im guessing the wall thickness of the carbs is 3.5mm which makes it 39mm so the kit should fit.. In theory
Not my picture, Found on the internet
bikerbiffo
Post by bikerbiffo »
thomas have you sorted the restrictor kit out? i'm in the process of removing one from my son's superfour 93
this is the proper job with certificate..if you had it fitted at a garage they could send certificate off with chg of name
i'm in barnsley too
if not once i've removed it i will take photo's and either offer it on this site first then flea bay...but i may swap kit for a tank.
cheers
martin
The Novice
Bike owned: NC23 NC30 CRM250
Post by The Novice »
not sure if this will help for your particular bike but porndoguk on here sells restrictor kits v cheap. Ask him.
Thomas
Bike owned: Gpz900r
Post by Thomas »
bikerbiffo wrote:thomas have you sorted the restrictor kit out? i'm in the process of removing one from my son's superfour 93
i'm in barnsley too
cheers
martin
Yes, i passed my test on the third and bought this kit.
http://www.ebay.co.uk/itm/Honda-CBR-400 ... 337a2432a0
Works perfectly, bike revs, sounds sounds same.. Not much difference in speed also.
Where in barnsley? Im at ̶C̶r̶i̶m̶e̶t̶h̶o̶r̶p̶e̶ Grimethope.
Hope this helps,
p.s, i would have responded yesterday but it wouldnt let me log in to the site. (Still wont, im using internet explorer to login now)
Thomas
Bike owned: Gpz900r
Post by Thomas »
i'm in barnsley too
cheers
martin
Oops, I thaught u wanted a restricor kit, sorry..
Anyway, i have emailed you about a tank.
