RVF400 Neutral light problem
Posted: Tue May 22, 2012 12:23 pm
by Andy_Edw
My neutral light on my nc35 flickers on & off when its in neutral, So i can't leave the bike running while on its stand because it thinks its in gear
Any suggestions?
Andy
Re: RVF400 Neutral light problem
Posted: Tue May 22, 2012 12:37 pm
clean the neutral switch connectors...
Posted: Tue May 22, 2012 12:47 pm
by Andy_Edw
Where are they located?
Posted: Tue May 22, 2012 12:52 pm
err..down near the gearbox - right hand side if I remember ! Near the dipstick
Posted: Mon Jun 04, 2012 9:22 am
by Mavirick
Change the bulb
Posted: Mon Jun 04, 2012 7:32 pm
by Andy_Edw
I checked all the wires, They were all fine
Can you even change the bulbs lol?
Posted: Mon Jun 04, 2012 7:37 pm
by ibby4585
You sure you got the right wire? It's a single spade end connectors thats really tight against wire easily to dislodge.
Posted: Mon Jun 04, 2012 9:12 pm
by hannakournikova
Check clutch diode with working one. It's lhs sitting on the bike behind arse
Posted: Tue Jun 05, 2012 12:27 am
by magg
Check that neutral switch gives consistent ground signal by measuring its resistance to chassis with a multimeter while the engine is running.
