cb400sf parts compatibility
Posted: Mon May 21, 2012 12:08 pm
by peppiiino
Hi all,
I checked the radiator fan on my 92 cb400sf and it's not working
I'm finding very hard to get a radiator fan for the bike, do you know if the cb1's is the same??
or any other honda model that may use the same, or a similar but compatible one??
cb500? cbr400??
Re: cb400sf parts compatibility
Posted: Thu May 24, 2012 3:57 pm
by peppiiino
any idea anyone???
maybe the cb1's could fit???
Posted: Tue Jun 05, 2012 9:56 pm
by frogdon
This might not be massively helpful, but just in case... are you sure it's the fan (i.e. not the temperature switch) which is faulty?
A previous owner on mine wired the fan straight up to a switch, so the fan doesn't come on automatically, but can be switched on using a switch on the bars.
Maybe your temperature switch has failed?
If you've tested already, please ignore me! Just thought it might be helpful as there were no other takers.
Posted: Wed Jun 06, 2012 10:44 am
by peppiiino
the first time i did the test it wasn't working
then i tried again and i found a good earth point and the fan went on :)
I opened another thread here because i want now to instal a manual switch, i'm thinking to put it right next to the fuel tap somehow..
Posted: Wed Jun 06, 2012 1:50 pm
by frogdon
Ah, fair play. I've just had a browse through your other post. I have mine next to the switch gear, and it's OK, but it is on a januty angle.
Must get round to moving it at some point. Just another job on the list
